iLogic - create Workplane and Workpoint
I need to create iLogic rule to create new Workplane with specific name, offset by 0 mm from selected face or from origin plane and then create Workpoint on intersection of 3 selected planes/faces, also with specific name.
I need to use it for some measurements from center of gravity.
Thank you.
Sergio.D.Suárez
Hi, With this rule you can create a work point by selecting 3 planes or three flat faces.
oDef = ThisDoc.Document.ComponentDefinition
Dim face1 As Object
face1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select Face")
Dim face2 As Object
face2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select Face")
Dim face3 As Object
face3 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select Face")
Dim oWPoint As WorkPoint
oWPoint = oDef.WorkPoints.AddByThreePlanes(face1 , face2 , face3)
oWPoint.Name = "My_New_Work_Point"
With this rule you can create a work plane parallel to another plane or face at a certain distance.
Distance= 2' Units in mm
Dim face As Object
face = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllPlanarEntities, "Select Face")
Dim oWPlane As WorkPlane
oWPlane = oDef.WorkPlanes.AddByPlaneAndOffset(face, Distance/10)
oWPlane.Name = "New_Work_Plane"
 If this answer has served you please mark it as an accepted solution. Thank you . regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Togo
Dim face1 As Object
Dim face2 As Object
Dim face3 As Object
Dim face As Object
Hi, thank you for your answer.
Your rules are working in Part, but not in my Assesembly. I need to use it in Assembly.
Hi, thank you, me too, i don't create in asssembly, help me 😅
'GET FOR ASSEMBLY
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
oPoint = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartVertexFilter, "CHỌN POINT_1")
'Dim POINT_1 As WorkPoint = oAsmDef.WorkPoints.AddByPoint(oPoint)
POINT_1.Name = "POINT_1"
