iLogic - Bulk Feature Browser Rename
jason_snyder
jason_snyder
Hi All,
I'm currently looking for a solution to bulk rename browser items.
I've attached photo showing how to rename one at a time. However, this is time consuming as I have 300-400 to go.
I have a excel spread sheet marrying current name to future name. Cell A1 = Work Plane 88, Cell B1 = WP88 etc.
Does anyone have code so I can quickly rename the rest of my 300-400 work planes via my spread sheet?
Cheers
mcgyvr
You will just need to do a loop (for each) through each workplane name and use excel find row to find the one matching your workplane name then change the name to the cell next to it..
See if you can figure it out from here..
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2015...
If not please post your excel file and ipt file and someone can whip something up for you..
Curtis_Waguespack
Hi jason.snyder,
I don't have the time to  include the Excel part of this, but here is a quick example of how to rename all work planes (skipping the origin planes).
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
oDoc = ThisApplication.activedocument
i = 1
For Each oWorkPlane In oDoc.ComponentDefinition.WorkPlanes
	'skip origin planes
	If oWorkPlane.IsCoordinateSystemElement = False Then
	oWorkPlane.Name = "WP" & i
	i=i+1
Next
Curtis_Waguespack
Another option:
i = 1
	'skip origin planes
	oWorkPlane.Name = oWorkPlane.Name.Replace("Work Plane", "WP")
Next
mcgyvr
Great examples from Curtis (again.. of course)...
Assuming that the naming is as simple as Work Plane 88 to WP88 then no excel is needed...
jason_snyder
Thanks Curtis,
Both your codes work perfectly, However, just one more question ...
How do I get the end number in the rename to increment? Instead of going 1,2,3,4 etc, I want say 0,5,10 etc.
I thought where i = i+1 you'd have i = i+5, though this comes with an error. Any thoughts?
Cheers
jason_snyder
Disregard previous, I found the error.
To get the i = i+5 working I had to alter the "WP" in this line: oWorkPlane.Name = "WP" & i. & then re-run.
All works. Thanks again Curtis. So speedy now.
Cheers,
Jason Snyder
