iLogic Browser Disappears when using Copy Design from Vault Browser
rodney.pudneyTNG8B
rodney.pudneyTNG8B
When using the new copy design feature in Inventor 2022.1 .1 (Build 234) my ilogic browser tab disappears and the only way to get it back is to restart.
Is this a known bug in Inventor 2022.1.1 ?
johnsonshiue
Hi! You don't need to restart Inventor. Go to View -> User Interface -> check iLogic. The other option is to click on the plus sign in the browser tab -> select iLogic.
Many thanks!
Software Test Engineer
rodney.pudneyTNG8B
@johnsonshiue Yes i have tried that.. but it still doesn't show.  the only way i have worked out to get it back is to restart my inventor.
it actually doesn't even show
rodney.pudneyTNG8B
johnsonshiue
Hi Rodney,
Many thanks for sharing the screenshot! Something is wrong. It seems that iLogic add-in was not fully loaded. There should be a separate iLogic entry right below iLogic Log. A few things to check. Make sure all critical Windows updates are installed and the appropriate .Net is enabled (.Net 4.7 for 2019 and 2020; .Net 4.8 for 2021 and 2022).
I don't believe this is graphics related.
Thanks again!
