iLogic and Scaling View Size Automatically
chayman
chayman
Hi there,
I was trying to find any information regarding my questions within the forum but I did not have any luck.
My problem: I have a master assembly that is associated with a master drawing. The master assembly can double/tripple/or even shrink by as much in size. Each time I have to go back into the drawing, scale it so it looks presentable on the dwg, and then fix around all the dimensions accordingly - this is probably the most annoying because the dimensions are always off center and out of line everywhere.
Is there a link someone can show me or a past forum page that can push me in the right direction? Any help is appreciated!
Craig H
Curtis_W
Hi chayman,
Try this link:
https://forums.autodesk.com/t5/inventor-forum/automatic-scale-and-view-position/m-p/5784680
Or this one:
https://forums.autodesk.com/t5/inventor-forum/change-drawing-scale-with-ilogic-upon-parameter-change...
Also just as a tip, you can search and ask programming questions of this type on the Inventor Customization forum too:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
