Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
iFeature - Punch Tool - feature moves as I switch back and forth between model states
Nick_ritacco
Nick_ritacco
Using Inventor 2024 Build: 153
I have a part with multiple model states.  The parts feature an iFeature - Punch Tool (same for both parts).  As I switch between / back and forth between model states, I can watch the feature physically move across the screen.  If I open the respective drawing, the feature has moved as seen in the model.  I can re-build, or just double click and immediately close the iFeature, and it re-positions to where it belongs.  But, when I click on a different model state, the iFeature starts to walk across the screen again.  I cannot attach the files, but screenshots below should help explain.  Thank you
Nick_ritacco_2-1734638117199.pngNick_ritacco_2-1734638117199.pngNick_ritacco_3-1734638339172.pngNick_ritacco_3-1734638339172.png
johnsonshiue
Hi Nick,
The behavior is certainly wrong. Either the punchtool was not authored correctly or constrained correctly. Or the punchtool is not handled properly by Inventor.
Try this. Edit the punchtool feature in the part -> check "Unfold" option. Does it work better?
If not, please share the file here or send it to me directly ([email protected]). I would like to understand the behavior better.
Many thanks!
Software Test Engineer
Nick_ritacco
Software update resolved the issue.  Thank you!
