IF function in Parameters
spi82UU6
Message 1 of 12
spi82UU6
It would be a very good thing if it was possible to use the "IF" function when specifying the values ​​of the parameters. In many cases this would help the work. There are components where, for example, the pattern should be bound to a condition, this is very difficult or not possible at all without the "IF".
Accepted solutions (3)
Replies (11)
Message 2 of 12
kacper.suchomski
Hi
It's possible. You can do it all with iLogic.
iLogic allows both assigning conditional values ​​and linking parameters between files, which is useful e.g. in the above-mentioned patterns.
Kacper Suchomski
Message 3 of 12
johnsonshiue
Hi! There is a way to write a parametric expression to do "if, then" but it largely depends on the complexity of the condition. Please share an example of the desirable "if, then." I would like to see if there is a parametric expression solution without using an iLogic rule.
Many thanks!
Software Test Engineer
Message 4 of 12
spi82UU6
I need only a simple if/then solution.
A = 10 mm
B = if "A=10" then "B=12" else "B=15"
Or
B = if(A=10;12;15) like in Excel 🙂
That's all.
Have a nice day,
Sandor
Message 5 of 12
kacper.suchomski
If A=10 Then
B=12
Else
B=15
You can paste this code into an iLogic rule.
Of course, you must replace the symbols with the actual names of the parameters.
Kacper Suchomski
Message 6 of 12
aurel_e
Other users have shown previously creative ways to compensate for that...
In your case the B would be:
( 1 ul - sign(abs(A1 - 10 mm) - 0.001 mm) ) * 12 mm + sign(abs(A1 - 10 mm) - 0.001 mm) * 15 mm
Message 7 of 12
johnsonshiue
Hi! There is a simpler equation to use for this case.
B=sign(( A / 1mm - 10 ul )) * 3mm + 12mm
Many thanks!
Message 8 of 12
aurel_e
@johnsonshiue This is resulting 12 for A<10.
Message 9 of 12
SBix26
In @johnsonshiue 's equation, just add the absolute value:
B=sign(abs( A / 1mm - 10 ul )) * 3mm + 12mm
B is 15 unless A is exactly 10.
I, too, thought that the sign function would return -1 for negative, 0 for 0, and +1 for positive, but that's not the case; it returns +1 for > 0, 0 for <= 0
Sam B
Inventor Pro 2026.0.1 | Windows 11 Home 24H2
Message 10 of 12
spi82UU6
Thank you so much!
Message 11 of 12
cfairfowl
Hi Johnson.
My old HP41 programming allows me to add x<=y goto program line and this can be stop the program.
if x>y goto program line, add 1 to sto+ 01 and re calculate using the new value.
This loops, calculates a triangle or something and when the desired value is matched I can then read off the angle and the other sides.
I would love to be able to this in Inventor parameters so I can control constraints to give me a precise value without having to tweak dimensions.
Thanks for all the help you give us guys - it is much appreciated.
Message 12 of 12
johnsonshiue
Hi! Yes, indeed, it will be great to allow conditional statements in parametric expressions. I believe the project team is aware of the request. In the meantime, you may use an iLogic rule or a combination of min/max to generate conditional behaviors. Please feel free to share an example that you would like to have conditional behaviors. There should be a way to do it.
Many thanks!
