idw to dwg code
Hello?
My name is SW Park.
I have a question about the Inventor idw to dwg code.
I am trying to change the idw file to dwg.
Each dwg is changed to a compressed file including fonts, but I want to change it to a dwg file only.
Can you tell me how to fix the code?
And I want to know the explanation of the code, where can I find the relevant manual?
[EXPORT SELECT OPTIONS]
AUTOCAD VERSION=AutoCAD 2007
CREATE AUTOCAD MECHANICAL=No
USE TRANSMITTAL=Yes
USE CUSTOMIZE=No
CUSTOMIZE FILE=Design Data\DWG-DXF\FlatPattern.xml
CREATE LAYER GROUP=No
PARTS ONLY=No
[EXPORT PROPERTIES]
SELECTED PROPERTIES=
[EXPORT DESTINATION]
SPACE=Model
SCALING=Geometry
MAPPING=MapsBest
MODEL GEOMETRY ONLY=No
EXPLODE DIMENSIONS=No
SYMBOLS ARE BLOCKED=Yes
AUTOCAD TEMPLATE=
DESTINATION DXF=No
[EXPORT LINE TYPE & LINE SCALE]
LINE TYPE FILE=COMPATIBILITY\Support\invANSI.lin
Continuous=Continuous;0.
Dashed=DASHED;0.
Dashed Space=DASHED_SPACE;0.
Long Dash Dotted=LONG_DASH_DOTTED;0.
Long Dash Double Dot=LONG_DASH_DOUBLE_DOT;0.
Long Dash Triple Dot=LONG_DASH_TRIPLE_DOT;0.
Dotted=DOTTED;0.
Chain=CHAIN;0.
Double Dash Chain=DOUBLE_DASH_CHAIN;0.
Dash Double Dot=DASH_DOUBLE_DOT;0.
Dash Dot=DASH_DOT;0.
Double Dash Dot=DOUBLE_DASH_DOT;0.
Double Dash Double Dot=DOUBLE_DASH_DOUBLE_DOT;0.
Dash Triple Dot=DASH_TRIPLE_DOT;0.
Double Dash Triple Dot=DOUBLE_DASH_TRIPLE_DOT;0.
