Ok, I've got 2 idw's that refuse to check in. Both drawings are different iAssembly configurations of the same assembly, there is only 1 part difference between the two. The drawings are basically identical besides that 1 part difference. I have been having trouble lately to get them to check-in to vault.
The most recent thing I did to the drawings was update the revision history table and add tags. The update was the addition to a couple label tags.
The previous time I had them checked out, I struggled to get them checked in too, but I finally did manage it. This time I've done all the tricks I can think of: restarting both Inventor and Vault, rebooting the computer, opening and closing the idw's, updating the properties in the vault tab and running updates. Vault and Inventor are both up to date, all parts and subassemblies are checked in. The only thing that is not checked in, and has the green bubble under the vault browser tree is the top level idw that I am trying to get checked in.
When I hit check-in, I get the window popup that says " 'filename.idw' must be saved before it can be checked in. Do you want to save and continue?"
I've done this I don't know how many times. Sometimes if I freshly just reopened the file, it will look like it did something as it will cycle from sheet 1 to sheet 2 and back, but it will never bring up the window to check it in. Even just closing the file only asks if you want to save it, it never says anything about wanting to check it in. Even the idea of "maybe it will just work tomorrow" isn't working, as I have been trying to check these in since last Thursday and it is now Monday.
I've exhausted all the tricks I can think of, and I haven't seen quite this problem proposed in the forums. The one that sounded the closest said it just happened to work when he tried it the next day and did not offer a workable solution.
Any help would be appreciated!
