idw lighter lines in one view
Hi all
what's the reason why one assembly in the same view has lighter lines then the others?
and as you can see, this lighter assembly is also visible at the location of the beam (the horizontal) while normally this assembly is under the beam so you shouldn't see that part
see prt screen please
johnsonshiue
Hi! The only logical reason I can think of is that the view geometry on the right is on the default Visible layer, while the one on the left is on the default Visible Narrow layer.
Many thanks!
Software Test Engineer
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous it looks like you have a lightning bolt in the browser, can you go to the Manage Tab and Rebuild All within the assembly?
It appears that the beam is bleeding through the other parts which sounds like it shouldn't be happening.
Whenever I see this it is typically because of bad bodies, skewed views/section lines, sick parts, or raster/vector loading issues.
I'm assuming that the view linetype hasn't been altered and should be the same as the view to the right, but looks like it is set to visible narrow.
Can you inspect the view and make sure it is straight on, not containing sick parts, and report back? Thanks!
Please select the Accept as Solution button if a post solves your issue or answers your question.
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous were you able to inspect your drawing an figure out where the line thickness was affected?
