Inventor Forum
iCopy problem
3 REPLIES 3
kresh.bell
205 Views, 3 Replies
iCopy problem
what does this mean? Does anyone have an idea how to solve this? I am pretty sure that the structure of the template has not been changed
it happens when I try to edit the parameter in the already placed iCopy
The strange thing is that when I edit the same parameters during insertion, everything works perfectly
3 REPLIES 3
johnsonshiue
in reply to: kresh.bell
Hi! Please share the files that exhibit the behavior here or send them to me directly johnson.shiue@autodesk.com. I would like to understand the behavior better. It sounds like a limitation but I would like to confirm it.
Many thanks!
Software Test Engineer
kresh.bell
@johnsonshiue, many thanks for your support by email
johnsonshiue
Hi Kresh,
Just to provide a bit more detail of the findings without disclosing the design. This is a limitation in iCopy workflow. It seems taht iCopy assembly should not have component patterns (circular, feature-based, or rectangular). On placement, it seems to work fine. But editing will lead to the error as shown above.
To recplicate iCopy assembly, it has to be done on placement. There is a Pattern tab in the Placement dialog. You may replicate the iCopy component in the selected direction (workplane).
Many thanks!
