iCopy - Can a User Parameter be used in the Pattern Count ?
Message 1 of 1
I have an iCopy pattern based on a feature pattern.  The feature pattern is subject to change quantity which requires me to edit the iCopy pattern and update the Pattern Count manually within the Constrain iCopy dialog box.  I have a user parameter which is set to the quantity which is used to modify the base feature pattern - however I am unable to select it within the iCopy Pattern Count.  Actually I am unable to select any parameter within the iCopy Pattern Count.  Is this correct or am I missing something?
Thanks;
Nick
Replies (0)
