Using: Inventor Profession 2019. (still waiting for them to upgrade)
Hello, I have an iAssembly I'm creating for a standard design with a family table... The assembly is simple, C shape with a gusset at each end and 1 in the middle. The length changes per the family table and when it gets longer it receives more gussets and when shorter it receives less gussets... I'm using the iassembly to reduce the qty of components in the component pattern and I use exclude to turn off welds too. Which usually retains everything until called upon. But in this case, when component pattern qty is reduced to 1 lower in value, it outright deletes the welds... Again normally this isn't an issue with constraints and other objects I exclude. So I'm confused on how I can make this work... Can you guys get the welds to return?
I went ahead and created a very simple example iassembly for you guys to test this on. Just open the file. (Hopefully it doesn't complain too much about paths). And activate the 2nd part in the part and you'll see that weld 5 is deleted, not excluded.
Inventor: Model States is not a replacement for iParts / iAssemblies. It does not have all the same features yet and does not communicate well with our large currently in use libraries. 😞 https://forums.autodesk.com/t5/inventor-ideas/model-state-support-tabulated-parts-list/idc-p/11360616
