I want to use part sketch in assembly
przemyslaw.galczynski
Hello
I have weldment assembly and I want to make machining operations in this assembly.
Also, in one of the parts in this assembly, I have sketch in a part with geometry that I want to machine.
Is there any way to use that part sketch in assembly machining operations?
johnsonshiue
Hi! You will need to turn the sketch into body geometry in a part file. Then you can project the edges from the part body to an assembly sketch.
Many thanks!
Software Test Engineer
