I try to connect my inventor to export my CAD to MATLAB but after enabled Simscape Multibody Link Inventor Plug-in and restart my Inventor there's no Add-ins of Simscape to add.
Solved by swalton. Go to Solution.
Have you started a support case with Mathworks? I suspect that they will have the most information about the MATLAB plug-in.
Is the version of Inventor you are using supported by the version of the Mathworks plug-in you are using?
Steve Walton
Hi! This may be a MATLAB install issue. But, you may be able to correct it by yourself. Find the addin load file (.addin extension). Then drop it in the following folder.
C:\ProgramData\Autodesk\Inventor 2021\Addins\
Many thanks!
Hi! What release of Inventor are you running? The path mentioned above was for 2021.
Many thanks!
Hi! Then the add-in files should be under "C:\ProgramData\Autodesk\Inventor 2022\Addins." If not, search for the MatLab addin file and copy&paste it to the above path.
Many thanks!
Hi Sir, Sorry but I've searched entire C and D drives already including the folder you've mentioned. I couldn't find any .addin file. (btw I have both inventor and Matlab in D drive)
Shouldn't this be the problem!
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Hi! Then I am sorry I run out of ideas. This particular add-in file was not created by Autodesk Inventor. You may want to approach Matlab.
Many thanks!
Mathworks Support:
https://www.mathworks.com/help/matlab/matlab_env/contact-technical-support.html
Steve Walton
Hi there, I'm having the same issue, Inventor 2022. Did you find a solution at the end ?
Thanks!
are you able to share the *.addin file?
Arthur Knoors
Ok I uninstalled 2022 and installed 2021 and it works. Thanks for the help ! 🙂
Could you upload the *.addin file.
Maybe I have a solution !
Arthur Knoors
I can't find any .addin file but here is the addin package to run in Matlab. I hope it helps.
