I'm trying to convert an inventor to .step but the image is lost
Message 1 of 9
Hi to all, I'm trying to convert an inventor to .step but the image is lost. you will find enclosed two images (.jpg).
any ideas??
I inserted the image as a decall and still lost it.
Replies (8)
Message 2 of 9
CCarreiras
Hi!
When you convert to step, you will lost some data. Images is one of these things you will lost.
CCarreiras
Message 3 of 9
STEP can only store geometry and basic appearance. Mapped images aren't stored with STEP.
Message 4 of 9
Do you know if there is an other file that could work? (.iges for example )
Thank you
Message 5 of 9
mcgyvr
Thank you
As far as I know NO neutral (iges/step,etc..) CAD format will retain the image..
What are you trying to do?
What software are you trying to pass this information to?
Message 6 of 9
I'm trying to transfert that file to a customer.
I want to convert the file so i can opaned in adobe 3d and send it to my customer.
I also tried to open it with Naviswork and the image is still missing.
Thanyou
Alfredo T.
Message 7 of 9
JDMather
What does the customer need with the file?  Simply to view the contents?
If so, there might be several solutions.
Autodesk just released a new viewer that is supposed to view many different types of files (I haven't downloaded it yet to experiment).
Message 8 of 9
the costomer just need to view the file.
Thank you
AT
Message 9 of 9
JDMather
First I would try Save As *.dwfx
If that doesn't work - then I would investigate the new software recently released by Autodesk.  I think it would allow the customer to view the Inventor file directly (but they would have to install something).  There is also Inventor View.
