I cant create an Item (The Create button is greay)
bernhardstackl
Observer Observer
bernhardstackl
Observer
Observer
hi, i use inventor pro 2021 but i cant use the create button for no reeason. i was downloading the whole software again and its still not working
dutt.thakar
@bernhardstackl
Can you reset the version of Inventor using the reset utility tool? You can search for it in the taskbar and try doing it, make sure to close your all Autodesk programs and once you reset open and see if that's helpful.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
mcgyvr
I believe this is related to your Windows user permissions.. You really need to have local admin rights..
Close Inventor then right click on the Inventor icon and select "Run as Administrator".
Does that work better?
JDMather
In addition to the other comments - make sure that you have not started Inventor in Read-only Mode.
