Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Inventor Forum
I can't sculpt my design on Inventor.
3 REPLIES 3
Carlos.cuartas144
503 Views, 3 Replies
I was designing an object and wanted to fill an area under a curved slope at the bottom of my object. So I searched up ways to fill areas completely without leaving an empty pocket in it. The easiest way I found was putting up patches and then using the sculpting tool and following the video step by step (link at the bottom). Every time I tried to do so it came up with an error or nothing at all. I attached the file of my design as well with the patches I currently have.
Can someone please explain what I am doing wrong, thank you in advance.
 https://knowledge.autodesk.com/support/inventor-products/getting-started/caas/screencast/Main/Detail...
3 REPLIES 3
blandb
in reply to: Carlos.cuartas144
Is there a reason you cannot just extrude "to next" and fill in the void?
Hope this helps!
Autodesk Certified Professional
Carlos.cuartas144
in reply to: blandb
The reason I can't do that is because it would leave an empty space inside the object that I don't need. Id like to 3d print this and leaving pockets of air like that would slow the print time, make the object heavier, and waste filament.
Thanks for trying to help though!
blandb
I have sent the model in 2019, but I have also shown screen shots of just the area I feel you wanted filled.
