Hypoid gear
Hypoid gear
efeizollahi777
Hypoid gear
efeizollahi777
Hello every body.
I want to design hypoid gears in autodesk inventor but in inventor there are just spur gears, worm gear and simple bevel gear. Can enyone help me how to do that in Inventor?
If not please tell let me know if there is a software that I can design hypoid gears.
Thank you so much
Esmaeil Feizollahi
Frederick_Law
efeizollahi777
Thank you for your respond Pineapple. I installed geartrax for inventor, it has all typical types of bevel gears for example straight bevel gear, spiral bevel gear, zerol bevel gear. But unfortunately seems it has not Hypoid gear.
If I'm wrong let me know please.
Thank you
Esmaeil Feizollahi
Frederick_Law
If GearTrax don't have it, I don't know where else.
Maybe contact them and ask.
johnsonshiue
Hi! If you can figure out the tool and the path to use, I suppose you will need to use Solid Sweep to make the cut.
Many thanks!
Software Test Engineer
al28975
Observer
Observer
lena.talkhina
Hello @efeizollahi777  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
