- Mute
- Permalink
- Report
The attached assembly image shows a subassembly that is a servo motor with an arm and link that I want to add a rotational joint to for animation.
The servo, pink link, and blue arm are in hitec_hs_648mg_assy,iam which I have placed in the PitchFrameWeldment.iam. I want to ground the servo motor, but not the link or arm. I have made the link and arm flexible and can rotate them independently by dragging with mouse. When I create a rotational joint between the pink link pin and the clevis hole that's on the tube, the entire subassembly rotates.
How can I fix this?
--Bob
AutoDesk PDS 2014
Windows8 64bit / Asus P9X79 / i7 3820 / 32GB RAM / 256 GB SSD / nVidia K2000D / Dual 27" LCD
AutoDesk PDS 2014
