HOW TO USE iPART and iassembly for frame generator to configured frame assembly
lohithna
lohithna
dear all,
i have a task to convert a frame generator part from solid works part to inventor
i have a solid works part , i facing to configure in inventor as similar to solid works part solid works model imagesolid works model imagesketch for frame generation for inventorsketch for frame generation for inventortable valves , frame member size given starting of column starts with w5 or w6table valves , frame member size given starting of column starts with w5 or w6
Mark.Lancaster
@lohithna
So are you considering this as your frame skeleton that will be inserted into an assembly and then frame members are added?
If you're actually using Inventor Frame Generator it can't be based on an iassembly   Each model must be separate.
Mark Lancaster
Cadmanto
Mark is correct.  The problem is, the way FG works is it uses a part sketch to create the frame members, miters and trims.  If you try and remove any part of it through iassemblies, the whole FG assembly will fail.  The closest you can come to what you are describing is to have the complete FG assembly turned on or off in an upper level assembly.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
lohithna
so what the best option can configure for each frame configuration
lohithna
here is attached solid works part ...inventor difficult create
Cadmanto
Three separate FG models.  That is the safest best method.  FG is a great tool, but it can be complicated.  Especially when it comes to the naming of the components and folder structure.
Inventor Pro 2018
Best Regards,
Scott McFadden
