How to update zone field in revision table in Inventor drawing?
Message 1 of 11
Hi there,
Is there some way to update the data into column "Zone" in revision table as its related flags move around the drawing?
For example, if a revision table has 3 lines, revisions A, B and C, and in this last one, and at first moment I just put 3 flags in zones... let's say D1, E1, F4. After that, I moved the views and the flag now are located in C7 (before was D1), D4 (before was E1) and H8 (before was F4). How to update this data in revision table automatically?
Also, I believe this is the same concept if the former revision flags change its position the related zone fields would update, is it correct?
Thanks in advance for all your support.
Kind regards,
Hugo
Replies (10)
Message 2 of 11
As far as I'm aware there is no way to currently achieve this in Inventor.
Message 3 of 11
johnsonshiue
Hi! It might be doable via iLogic rules or API. But, the amount of work to make it happen may be much greater than just changing it manually.
Many thanks!
Software Test Engineer
Message 4 of 11
So... what do you guys think if I suggest this in Idea Station?
Message 5 of 11
I see no reason why not. Cheers!
Message 6 of 11
mcgyvr
I suspect that its a virtually impossible idea to actually implement and personally I wouldn't waste your time putting in the idea..
Message 7 of 11
I disagree with mcgyvr. There’s nothing wrong with inspiring innovation with ideas, no matter how impossible they seem. Adding ideas to the wish list is free and takes very little time and effort. Go for it and thank you for your contribution.
Message 8 of 11
harri_parker
Has there been any development on this so that Revision zone could automatically be filled in the revision table.
Message 9 of 11
johnsonshiue
Hi Harri,
I am not sure if AutoDraw App can help. Please take a look.
https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=5706339273400434437&appLang=en&os=Win64
Many thanks!
Message 10 of 11
dan_grossWY4VB
Observer
Observer
I would like to see the zones autopopulate. I am a semi-new user to Inventor and have just created titleblock/borders, etc. for my company division. I was disappointed to see that the zones dont autopopulate when dropping the revision tags. Not that anyone wants to hear this but Solidworks autopopulates the zones when dropping the revision tags. I am sure Autodesk can accomplish this also.
Message 11 of 11
dan_grossWY4VB
Observer
Observer
put the idea through!
