How to update file to current inventor release (2023)
sales5N2FF
Message 1 of 10
sales5N2FF
I just installed inventor 2023. I'm trying to use design assistant and am being told "the following file need to be updated to the current Autodesk Inventor release before they can be edited". I have opened the file and hit "save" and that doesn't resolve the issue. What do I need to do?
Replies (9)
Message 2 of 10
tobias
You can use migrate:
If you have a lot of files, you can use task schedular:
Tobias
The Netherlands
Inventor Pro 2026, Vault Pro 2026, AutoCad Electrical 2026.
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Message 3 of 10
mcgyvr
You can also go to tools...application options..Save tab and see if "Migration" is set to Yes/Save(Default Condition)
With each new release you will also want to migrate all of your templates and styles,etc...
If you go to the "Tools" menu you will see a "Migrate Settings" button that should walk you through that process.
Message 4 of 10
johnsonshiue
Hi! Or, you can use Task Scheduler 2023 and set up a migration task.
Many thanks!
Software Test Engineer
Message 5 of 10
sales5N2FF
Thank you for the replies all!
Message 6 of 10
mgreenTQ45F
I'm having the same issue. Tried all of the above steps and none of them are working
Message 7 of 10
johnsonshiue
Hi! To run Task Scheduler 2023, you will need to first register Inventor 2023 (last run). Could you elaborate the exact issue you have?
Many thanks!
Message 8 of 10
mgreenTQ45F
Figured it out. There was a single file from a library that had not been migrated and it caused all upper assemblies to be locked out in Design Assistant.
Message 9 of 10
Rafael_LeonZ2X
Community Visitor
Community Visitor
I am having the same issue. I followed the instructions but still get the message.
Also, I am seeing in the Migrate Custom Settings a message stating "Migrate settings from: Inventor 2021". I believe the last version we had was 2019. Will this pose an issue with the instructions you have provided?
I'm a new user with Autodesk Inventor.
Thank you!
Message 10 of 10
johnsonshiue
Hi! Please install 2023.0.1 update and 2023.2 update, followed by 2023.2.1 update. If it still fails, please share the setting xml file you are trying to migrate.
Many thanks!
