How to uninstall Autodesk when uninstaller is missing?
splintWFYFX
Message 1 of 8
splintWFYFX
I'd like to uninstall the Autodesk products I used in my engineering degree but the uninstall tool is missing and I cant uninstall through windows add remove programs.
I have Building Design Suite, Product Design Suite and Master Suite 2015.
How do I remove all of these?
David
Replies (7)
Message 2 of 8
EvanGu
The tool should still in your hard disk, try to find it in "C:\Program Files (x86)\Common Files\Autodesk Shared\Uninstall Tool\R1". Or get the attached file and try to launch the tool.
Evan Gu
Inventor/Fusion QA Engineer
Message 3 of 8
what happens when uninstall software doesnt work
Message 4 of 8
johnsonshiue
Hi! Microsoft FixIt tool comes in handy.
https://support.microsoft.com/en-us/help/17588/windows-fix-problems-that-block-programs-being-instal...
Many thanks!
Software Test Engineer
Message 5 of 8
Error 404 every time I go to download that from Microsoft.
Nevermind, will have to reset this whole machine
Message 6 of 8
@EvanGu Same issue as original post. I downloaded the tool, but because I deleted the programs and as many program files as I could using these instructions https://knowledge.autodesk.com/customer-service/download-install/remove-products/remove-windows-prod... before ever finding out that the tool existed, nothing shows up when I open it. What should I do?
Message 7 of 8
johnsonshiue
Hi! Please check out Microsoft FixIt tool. It is the most powerful uninstall tool on Windows.
Many thanks!
Message 8 of 8
dana_simison
I downloaded your uninstall tool, it runs but it does not find any Autodesk software to uninstall.
