I see this has been covered previously, and it seems there is no way of doing a centre line bisector for multiple lines and arcs and having them
join up smoothly as a chain.
my 2 work arounds are
1. retrieving the model sketches for the path of the sweep of the circle, and changing the linetype to chain
2. drawing the centre line as a sketch (ie like you would do it in autocad)
See my attached PDF
How does everyone else tackle this one..
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
Solved by kelly.young. Go to Solution.
I use the techniques you described, either retrieve model sketch or create drawing view sketch.
Sam B
Inventor Professional 2018.2.3
Windows 7 SP1
Thanks Sam
It looks like that is what most users, including us, do.
Leaving the centre lines and arcs overlapping does look
pretty ugly as well as unprofessional!!
I guess it would be pretty pointless posting an idea on this topic unless there was enough support.
I have just recently had 2 ideas archived because there was not enough support.
Therefore I am going to post my idea here first for comments and support.
If there is not enough support or enough reasons saying why it is not a good idea, I won't take it any further.
See also attached pdf which is a duplicate of this image, but clearer for viewing.
Michael Kovacik
--Cad (28 yrs)
---Cadkey (4 yrs)
---Inventor (4 yrs)
Higher Diploma Mechanical Engineering
Ex Member South African Institute of Mechanical Engineers
Ex Technician Member Engineering Council of South Africa
Collaborator (Rank 9) on Autocad & Inventor Forum
Certified Autocad 2013 & Inventor 2013 Professional
Authorised Autodesk Trainer
Hello @MikeKovacik4928 thought I'd consolidate a few similar ideas and post them here:
Drawing 'Automated Centerlines' support for path of sweep features
Centerline bisector should stop at end point of bend
Multi-Selection Centerline Bisectors
Please select the Accept as Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
Kelly
I see the idea has been put forward before, and it has been accepted and put forward for future consideration.
I will not therefore add my vote, as I presume it will appear in future versions of Inventor.
I have never used Automated centrelines before, I will investigate.
From reading what you have pointed to, I see, though, it has the same problems, regards having to trim.
Mike
Kelly
On second thoughts, I will put my vote forward on those ideas.
Mike
