How to test balsa wood
Is there a material add on for balsa wood complete with material properties so we can test?
mcgyvr
You can always add on yourself...
Not sure if Inventor can provide accurate FEA results as it performs linear material analysis only..
mpatchus
Material Properties of BALSA
https://www.matbase.com/material-categories/composites/polymer-matrix-composites-pmc/wood/class-4-wo...
Common Name(s): Balsa
Scientific Name: Ochroma pyramidale
Distribution: Tropical regions of the Americas; also grown on plantations
Tree Size: 60-90 ft (18-28 m) tall, 3-4 ft (1-1.2 m) trunk diameter
Average Dried Weight: 9 lbs/ft3 (150 kg/m3)
Specific Gravity (Basic, 12% MC): .12, .15
Janka Hardness: 90 lbf (390 N)
Modulus of Rupture: 2,840 lbf/in2 (19.6 MPa)
Elastic Modulus: 538,000 lbf/in2 (3.71 GPa)
Crushing Strength: 1,690 lbf/in2 (11.6 MPa)
Shrinkage: Radial: 2.3%, Tangential: 6.0%, Volumetric: 8.5%, T/R Ratio: 2.6
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Is this built into Inventor 2017?
I don't see it in my material list.
JDMather
You can always add materials yourself.
Make it isotropic (even though wood is not) and use caution in the analysis.
Your instructor should be able to show you how to add a material.
If you can't figure it out - post back and I will find video instruction on the process.
