How to subtract one shape from another?
I have constructed a model of a small part. It is a bit larger than the actual part. The goal is to 3D print a custom case that can hold a dozen of these. The case is three solid bodies. The intent is to "press" the part halfway into the main body of the case, and then "press" the part halfway into the cover; the case body is a couple mm thicker than two part-semi-impressions, and the third body is a cover on the opposite side. Now the question is, given the model of the case and the model of the part, how do I go about doing the subtraction of a half-part from each of three solid bodies.
If I need to include the part as a fourth body, how would I include it in the multi-body part file I have. I thought I could do a cut when I placed these in an assembly (remember, the part model is larger than the actual part so these is about .5mm clearance in all dimensions) but this does not seem to be an option.
A simple example is creating a cylindrical hole evenly split between two solid extrusions.
Also, when I tried to do a "place" and added a constraint, I use the XY plane, which bisects the cylinder, as the constraint "selection one", the arrow points away from the solid object I want to embed it in; when I select the mating surface as "selection two", the cylinder rotates 180° in the XY plane and now hangs out the side.
Thanks in advance
joe
