How to split a spline into an arbitrary number of equal segments?
joh13399
Message 1 of 11
joh13399
Let's say I have an arbitrary spline, like so:
I need to split this spline such that I have up to 1024 equally-sized segments, specifically, I only need the first 1024th of the segment, the rest of it is idempotent.  To be clear, I need this to be *exactly* up to a 1024th of the spline, Measuring the total length and creating a line segment won't do for the precision required for this task, as the error multiplies with subsequent operations.
How do I produce this output? thanks!
Replies (10)
Message 2 of 11
j.palmeL29YX
I would export the spline into AutoCAD and there divide in the needed number of segments (with exactly the same length, not approximated by straight lines). and reimport the points into Inventor. For better visibility the image shows an example with only 100 segments.
(I don't know if that can be done in Inventor using a VBA macro [iLogic] too)
Jürgen Palme
Message 3 of 11
j.palmeL29YX
Additional question:
What do you need it for, what do you want to do? I can't believe that the given value of the length overall should not be precise enough.
Jürgen Palme
Message 4 of 11
joh13399
I'm making an arbitrary-path encoder, which means that I need slots in a part to a very-fine degree. 1024 slots is about the finest I need, so I used that number as a base for this question.
Message 5 of 11
j.palmeL29YX
And what about my suggestions to solve your problem?
And I still do not know (not understand) what you need: the points (coordinates) where the spline to divide, or the spline segments after splitting, or straight line segments between the points or ...?
Jürgen Palme
Message 6 of 11
joh13399
As far as your comments, I'm not sure that this precision will be enough. If i'm not mistaken, Autodesk Inventor uses 64-bit doubles for measurements, which gives 16 digits of precision, max. 16 digits, is pretty good, but it seems that any number of digits that I enter after 7 or 8 are truncated/rounded. Due to how error works in the system I'm designing, the effect is multiplicative (ie, the error = err1*err2*err3, etc). So even if I'm 0.00001 off, that will translate to a 1% error in the overall product. I'm not too familiar with autocad, so I'd need to see if such a solution will work. I will try it... the point output that you have is perfect for my application.
Message 7 of 11
j.palmeL29YX
If you use 1/1024th in an incremental manner, its calculation (base) error will be added 1024 times.
Perhaps you can use a Baseline dimensioning. Then also the latest point will be placed only with the base error.
(I hope you understand. My English skills are not good enough to explain it better 😞  )
Example for 1/10th:
Jürgen Palme
Message 8 of 11
JDMather
@joh13399
What version of Inventor are you using?
While I can certainly pattern a point along any arbitrary path into equal number of divisions, your Design Intent is still not clear to me.
Message 9 of 11
j.palmeL29YX
>>Here<< an example (for @joh13399 ) how that can be done (thanks to @JDMather  for remembering me).
For demonstrating I set only 50 points.
But as @JDMather too, I don't know what you will do with this result.
Jürgen Palme
Message 10 of 11
JDMather
@j.palmeL29YX
I don’t know where the OP is going with this, but I suspect they will also want to set Direction 1 for the pattern.
Message 11 of 11
kacper.suchomski
Hi
This is a sample solution that came to my mind.
But the tool and the method match the target, and as @JDMather mentioned - we don't know your target.
If you like this method, remember that if n - number of distances, then the number of points must be n+1.
Kacper Suchomski
