how to seperate a part have two solid without any bind?
yahyayaksiz
yahyayaksiz
greetings.
how can i seperate one solid body to two solid body. the solid have two part without binding. Solidworks have a command for this but I cant find it for Inventor. here solidworks tutorial photo.
note: I found this "girinti" features English is Indent.
Replies (11)
kacper.suchomski
Hi
Right-click on the solid and select Create Part, or in the Manage tab, select the Create Components tool.
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
yahyayaksiz
no @kacper.suchomski its not working.
attach your file
kacper.suchomski
LOL. After all, you just showed us a screen with two separate parts.
Save this assembly and the part files will appear in the folder you defined in the wizard.
Kacper Suchomski
yahyayaksiz
file attached in first comment.
yahyayaksiz
NO. There is have two parts in one solid body. they haven't any bind. it's like a if you subtract one object in AutoCAD and object haven't any bind, acad continue to accept there is one 3d solid.
Dont believe assembly tree list. there is another things name.
Update: I find a way with create mold design but its not easily. inventor probably haven't Indent features.
kacper.suchomski
I'm not sure what you want to achieve; because you are using the terms for 3 different purposes:
  1. separate
  2. subtract
  3. form
  1. If you want to separate the parts, just use the Create Component tool I mentioned in the first comment.
  2. If you want to subtract volumes from each other, just use the Combine tool.
  3. To create forms, the inventor has a special module that automates the work of creating a matrix and a punch. You don't have to do it manually. You only need the product model.
But after reviewing your model again, I think I understood - you want to separate the die from the core.
If so, you have several options:
  1. Use the mold design module
  2. Use the copy tool to extract the bodies, then derive the parts as I described in the first comment.
For the future - if you want to be well understood, try to use the names used in Inventor; this will give you a better understanding of your workflow. In this case:
  1. You have one part - ipt file
  2. One part has two solid bodies
  3. One of these solid bodies has several enclosed spaces (volumes).
Kacper Suchomski
blandb
Is this what you are looking for? This is all in one part still. From here you can then do Manage Tab > Make Components and then create an assembly of these 2 solids. Or are you trying to make mold halves? Can you explain what your ultimate end goal is?
Autodesk Certified Professional
kacper.suchomski
Look this:
Kacper Suchomski
johnsonshiue
Hi! I believe there are two lumps in the solid body. There isn't one command to separate the lumps into bodies. However, there is a workflow to achieve that. First, create a rectangular pattern of the body (distance = 0 and instances = 2). The two solid bodies will overlap. Hide one of them. Use Delete Face -> Lump selection -> select one lump. Unhide the other solid body and repeat the same process on the other lump.
Many thanks!
Software Test Engineer
yahyayaksiz
thanks for all pieces of advice. john's advice is a rapid method but inventor really need Solidworks'es Indent command.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
