How to reset texture and material library to default?
as187222
as187222
I’ve been messing around with the texture and material library, but I’m ending up with some loose ends and random files I accidentally left behind. I don’t want to clutter up my library, so is there a way to reset it to default? Thank you!
johnsonshiue
Hi! For Autodesk Material and Appearance Library, you will need to uninstall from Control Panel (or Autodesk Uninstall Tool). For Inventor Material Library, you will need to uninstall Inventor and reinstall Inventor.
Many thanks!
Software Test Engineer
