Announcements
How to remove all tweaks from a view in a presentation file
fsdolphin
fsdolphin
Is there a way to remove all of the tweaks applied to a view with a one click in a presentation file? What I would like to be able to do is copy and paste a view and than remove all tweaks instead of deleting one by one.
Thanks.
Filemon
admaiora
Which release do you have?
You can opne the Tweaks folder, in the browser, select all tweaks, then DEL key.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
If you don't have 2017 yet, the best way would be to view the tweaks in the Model Browser, right click -> expand all, click the very first component in the very first tweak, scroll down to the last component in the last tweak, hold shift and select it. You should now have every tweaked component selected. Simply right click and delete! Remember, you can't delete tweaks by selecting the tweak itself, you have to delete all the components in the tweak to get rid of it.
If you DO  have 2017, simply highlight all components in the main window, right click -> delete tweak -> all.
fsdolphin
I'm still in 2015 so your solution helps. by the way the option is `Expand All Children`. Thanks a lot.
fsdolphin
I'm still using 2015 so I don't think I have the folder you are suggesting. Thanks
