Inventor Forum
How to "Batch Demote"
3 REPLIES 3
J.VandeMerckt
319 Views, 3 Replies
Hi Everyone
I have a huge number of assemblies. All these assemblies have 3 Parts which I want to change into a subassembly.
I know I can open 1 assembly and demote these parts into the subassembly I need.
This is of course only for 1 assembly.
Is there a way to choose all these assemblies and demote all the parts into the subassembly at once?
Ideally without the use of Ilogic.
Thank you in advance for helping!
I'm using Inventor 2020 and vault basic.
Tags (2)
Labels (4)
3 REPLIES 3
Hi! Structural change has to be done via Demote workflow. I believe iLogic or Inventor API is needed, other than doing it manually.
Many thanks!
Software Test Engineer
Thank you, I'll look into that code in a while.
BR
Justin
Hi! Here is a related discussion. Please take a look.
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/demote-frame-member-through-api/td-p...
Many thanks!
