How to put text above a dimension line
Solved by pstollPF4G7. Go to Solution.
Solved by mcgyvr. Go to Solution.
Not exactly sure what you are wanting..
But simply double clicking on a dimension after placement will bring up the "Edit Dimension" box and you can simply type in whatever you want
@elevet To get the text above the line you probably want to update the Dimension Text style here:
Update the single line text location using the button circled in blue and the multi line text in red.
