how to move an AutoCAD overlay drawing
ggtoutounji
Message 1 of 15
ggtoutounji
I have imported an AutoCAD underlay drawing on a plane in a part. How can I move it? it says fully constrained.
Thanks.
Replies (14)
Message 2 of 15
blandb
Right click on the underlay and use translate to move it.
Autodesk Certified Professional
Message 3 of 15
johnsonshiue
Hi! Like Brad said, you can use Translate command to move it around. Or, you can right-click on the DWG node in the browser -> Redfine -> select a new plane and a center point to relocate it, similar to a 2D sketch.
Many thanks!
Software Test Engineer
Message 4 of 15
Cadmanto
On top of what has already been said, I would as I show below, in your sketch, turn on all of the contraints and figure out which one is preventing you from moving it.
Then, use, shown below, the move command windowing your sketch.
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 5 of 15
rhasell
Hi
I use a lot of site plan underlays, and added to everything mentioned, there is one instance where I have to make changes in AutoCAD.
When the underlay is too far from zero, IE a few kilometers, I have to move the AutoCAD geometry  closer to 0,0,0 in order for Inventor to make meaningful sense of the geometry.
Other than that, I use the Translate and Redefine tools as well.
Reg
2026.3
Message 6 of 15
ggtoutounji
thank you all for your help.
Message 7 of 15
I have Inventor 2019 and I don't see the "Reposition" or "Transfer" option when I right click the underlay
Message 8 of 15
blandb
Do you have the dwg icon in your model browser? If so, right click on the dwg icon and choose "translate".
Message 9 of 15
I've included a screenshot of what appears when I right click on the icon.
Message 10 of 15
blandb
You are in an assembly, you need to be in a part.
Message 11 of 15
jhackney1972
You are in an assembly.  Import the AutoCAD drawing into an Inventor Part and then you will see the Translate command.
John Hackney, Retired
Message 12 of 15
blandb
In your case, expand the DWG and then expand origins, alter the angle constraints to rotate
Message 13 of 15
the reason I have it in assembly is because i'm also going to be importing the Recap point cloud file (the building) on top of the DWG underlay (the building's 2D layout) unless there is a different approach to this
Message 14 of 15
johnsonshiue
Hi! In an assembly, the dwg file contains origin planes and the center point. Expand the dwg node in the browser. You may need to delete the existing assembly constraints and create new assembly constraints between the dwg origin planes and the assembly origin planes.
Many thanks!
Message 15 of 15
rhasell
Hi
There are two ways to do this, the fist is how you are doing it by placing the underlay directly into the assembly. This works, the translation and moving can be performed with constraints.
The other is by placing the underlay into a part, and then placing the part into an assembly. This is in my opinion the preferred method as you have a lot more control and options available to you with the underlay. For example being able to add work geometry and sketches. You can also constrain items to the underlay a lot easier.
There is still the issue of the underlay being too far from zero, for me personally, I don't even bother with translate, I just move the dwg file to zero in AutoCAD.  I also do basic layer control and line style formatting in AutoCAD, it's just easier this way.
See two small screen grab examples, the part and the resultant assembly.
Reg
2026.3
