How To Model Complex Shape
mickmac06
Message 1 of 10
mickmac06
Hi, I'm trying to model the base of a table which has a tapering circular base but the centre point of the post is off centre. I was going to just create the shape with the post in the centre and then use direct edit to drag the relevant faces off centre but this isn't working. I can't seem to get loft or sweep to work either. Can anyone give me some guidance on how to create this shape?
Accepted solutions (3)
Replies (9)
Message 2 of 10
CCarreiras
Hi!
First, the file on the image is missing... upload it.
Your goal is to replicate the geometry signed in the image?
CCarreiras
Message 3 of 10
CCarreiras
...Anyway...
Forget Direct tool to achieve that.
Some Loft with the rigth sketches will be the solution:
A quick example:
File attached v25
CCarreiras
Message 4 of 10
mickmac06
Thanks CCarreiras, the elliptical shape is the original shape, I needed to create a similar part but it needed to be circular, not elliptical. I did try the loft method but couldn't get it to work so I will take a look at your sample with great interest. I managed to achieve the shape by creating patches from the sketches and then using the split tool to remove the unwanted section - screen shots attached. Thanks for taking the time to respond so promptly.
Message 5 of 10
CCarreiras
Well, if it is circular, is even simple... i don't understand why all those patches and lofts...
Why not a simple revolve?!
CCarreiras
Message 6 of 10
mickmac06
A revolve would indeed be very simple, unfortunately the axis is off centre and there are three different shapes that need to follow through.
Message 7 of 10
CCarreiras
I mean... a simple revolve to be the base... then, create some guide lines, and loft:
Check the video:
(view in My Videos)
CCarreiras
Message 8 of 10
IgorMir
I don't see any particular hardships in creating the required model. Here is a sample in IV2020 format.
Cheers,
Igor.
Web: www.meqc.com.au
Message 9 of 10
johnsonshiue
Hi Mick,
I must be oversimplifying the issue. I am wondering if Revolve and Non-Uniform Scale may help. Just Revolve the shape as a new solid body. Then use Direct Edit -> Body -> Scale -> select the body -> Non-Uniform -> keep Z scale factor at 1.0 but change X and Y factors accordingly.
Many thanks!
Software Test Engineer
Message 10 of 10
lauri_barnhart
Hello, @mickmac06,
Just checking in—did the responses shared by @CCarreiras, @IgorMir or @johnsonshiue help clarify your question?
If so, please consider clicking the "Accept Solution" button on the post(s) that solved your problem. Doing so helps others in the community easily find useful answers.
If your question still needs more attention, feel free to reply here with an update. This way, other members can jump in with further suggestions or guidance to help you move forward.
All the best,
Lauri | Community Manager
