You are correct, segments will result that are most likely arcs and splines.
It is clear that additional capabilities like a 'cut normal' option need to
be implemented to overcome these limitations and produce a perfectly
circular and continuous cut result. In the mean time, by utilizing IV2008
you could apply one of the aforementioned methods to place the cut on the
folded model where you desire and then conduct a clean-up operation within
the new flat pattern environment. A new cut applied directly to the flat
pattern (perhaps in conjunction with an extrude to add back some material)
would give you a perfect circle that would be more dxf and annotation tool
friendly.
Seth
wrote in message news:5513887@discussion.autodesk.com...
Udaya, andrew...
these methods *will* result in holes that are circular in the flat, but
*will not* output circles to dxf (edit: just checked this in both 10 & 11).
What I had to do was to save the sketch with the projected flat and the
circles in it to dxf.
-B
Message was edited by: rblawson
