How to map sheet metal thichness to 2D header (not in BOM list)
How to map to thickness from styles editor for sheet metal parts, want to have thickness at the 2D header/title block for the template, Inventor 2019 pro ?
Sergio.D.Suárez
Hello, are you trying to add the thickness to the titleblock?
I think you should do this procedure.
I hope this helps solve your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Hey,
Thickness is given in the parameterlist.
You could add the Iproperty to your 2D-drawing by
iProperties.Value("Custom", "PropertyName")= Parameter("Part1.ipt.Thickness")
nd add the text to your title block like;
Hope this will help you,
Kind Regards!
works, but only for the first part placed at 2D, if i change thichness the 2D dont update at all?
thanks working, but when change the thickness the 2D dont update-i guess another issue
johnsonshiue
Hi! It should work. I don't understand why the change in thickness does not update in the drawing. Something is wrong. Please share an example here so forum experts can take a look.
Many thanks!
Software Test Engineer
Hi We solved it with another internal tool, but i think its because all properties not were exported
