Former Creo user here, although I've been using Inventor for the last 3 months and getting the hang of it.
However... I just can't figure out how to model this one particular sheet metal part in Inventor.
The bulk of the part is a shape that blends from an oval-ish profile on the bottom to a circular profile on the top.
For that part of it, the lofted flange tool (with a rip down the side) works just great:
However, I need the circular cross-section at the top, to then continue straight up and form a short cylinder (illustrated by the yellow sketch below):
All of my attempts to add onto this base geometry have thus far failed, so far I've tried:
-Creating a contour roll on the top of the loft (doesn't work as it doesn't connect the roll to the slightly non-flat top edges of the loft).
-Cutting away a tiny slice of the top surface of the loft to create a flat top surface for a contour roll (the contour roll then doesn't work as then the top profile isn't perfectly circular).
-Starting out with the cylindrical shape and then building the loft on top of that (again, non-connected geometry).
-Building a loft on top of the loft (again, non-connected geometry).
-Modelling as a solid object and then converting to sheet metal (problems with making it a flattenable sheet metal part, although this is the path I'm currently playing around with more).
-Extending the edge on the top surface using a 'ruled surface' (doesn't quite get the shape I need as it basically just continues to extend the loft/blend transition).
I know Inventor has to have a way to create this geometry as a sheet metal part somehow - I'm pretty sure this is something I could have done in Creo with the extrude sheet metal wall command - but at this point my limited Inventor expertise has left me scratching my head, and all the tutorials I could find using the lofted flange didn't give any insight as to how to add to the created loft geometry.
Any insight as to how to model this part would be appreciated! (At this point, the only solution I've been able to come up with is modelling the part as a normal 3d part, not sheet metal, which is far from ideal.)
Thanks!
-John
