HOW TO MAKE CIRCLES CONCENTRIC NOT IN THE SAME SKETCH
New_to_Inventor
Message 1 of 14
New_to_Inventor
Can someone PLEASE show me how to make relations to edges that are not in the same sketch?
I have projected the edge, made sure it is flat and planar so it's not an elliptical edge, but Inventor is not letting me select the yellow projected edge as a constraint.
Incredibly frustrating for how simple it should be.
Replies (13)
Message 2 of 14
Alexander_Chernikov
It would be much easier to give you some advice if you attached the model file, or at least a few screenshots where we could see what needs to be done....
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Message 3 of 14
johnsonshiue
Hi! The only logical reason I can think of is that the "circle" isn't a circle, though it looks like it. Try using Measure tool to check the "circle." Does the radial value come up?
Many thanks!
Software Test Engineer
Message 4 of 14
New_to_Inventor
It should be as easy as they get!! The circles need to be concentric, but Inventor will not acknowledge the existing edge- even when I project the geometry :*(
Message 5 of 14
johnsonshiue
Hi! If possible, please share the files in zip here or send it to me directly (johnson.shiue@autodesk.com). I would like to understand the issue better. The sketching behavior does not make sense to me.
Many thanks!
Message 6 of 14
sam
Are you constraining the Center Point? Or are you trying to constrain the edge?
Message 7 of 14
mluterman
First, you come on here with a nickname that can't help but rub anyone the wrong way.
Then you have a one-sided argument purporting to know the answer yourself.
Next, you claim it's simple, but can't figure it out.
That's the kind of attitude that keeps me from helping.
Message 8 of 14
sam
Use the Equal or Tangent Constraint for the circle edges. Use a Coincident constraint for the Center of the Circle. Easy peasy!
Message 9 of 14
New_to_Inventor
This is how I've been managing. Thank you!!
Message 10 of 14
New_to_Inventor
Fair enough!! Thanks for stopping by 🙂
Message 11 of 14
New_to_Inventor
I can't get the center point to show up 😕
Message 12 of 14
New_to_Inventor
Never claimed to know the answer. It COULD be concentric circles but that doesn't seem to work. It SHOULD be simple- but it's new.
Message 13 of 14
Curtis_Waguespack
Hi New_to_Inventor,
It should work as you expect it to. But since it does not it is likely due to geometry specific to your file. If you can not post your work file, you might create a simple example part to share that will demonstrate the issue you are seeing, so that others can better understand the geometry involved.
Hope that helps,
Curtis
Message 14 of 14
New_to_Inventor
Thank you!
