How to make a intersection curve to a usual sketch to extrude the sketch.
a.wassum
a.wassum
Hey everybody,
I have an Intersection line between a working plane and a part. Now I want this intersectioncurve in a new sketch to use this curve to extrude it to a solid.
I tried some things but most of the time I cant extrude a solid, just surfaces.
In the added picture, the blue line is meaned.
Do you have any ideas?
with kind regards,
Alex
blandb
I am not sure I'm following you. Can you share the part or a simplified version of what you are trying to do?
Autodesk Certified Professional
johnsonshiue
Hi! It looks like the intersection curve (project cut edges) is not closed. To create a solid body, the sketch must be closed. Please share the file here. Forum experts can help take a look.
Many thanks!
Software Test Engineer
