Hi everyone, I have created some codes in my ilogic but idk how to connect with the vba script,
help me in this
Solved by Sergio.D.Suárez. Go to Solution.
Hi, This is a code of how to trigger an external ilogic rule from vba.
Sub Run_iLogic() Dim RuleName As String RuleName = "00_New Nota_Gen_Sel" ' Your ilogicName here Dim iLogicAuto As Object Dim oDoc As Document Set oDoc = ThisApplication.ActiveDocument If oDoc Is Nothing Then MsgBox "Abra un documento por favor" Exit Sub End If Set iLogicAuto = GetiLogicAddin(ThisApplication) If (iLogicAuto Is Nothing) Then Exit Sub iLogicAuto.RunExternalRule oDoc, RuleName End Sub Function GetiLogicAddin(oApplication As Inventor.Application) As Object Set addIns = oApplication.ApplicationAddIns 'Find the add-in you are looking for Dim addIn As ApplicationAddIn On Error GoTo NotFound Set addIn = oApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}") If (addIn Is Nothing) Then Exit Function addIn.Activate Set GetiLogicAddin = addIn.Automation Exit Function NotFound: End Function
I hope this helps. regards
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
