Announcements
How to insert 'AutoCAD Blocks' into a Title Block
SEC_CAD
SEC_CAD
I want to add my company logo as a vector line drawing (not an image) into the title block of my DWG template.
I have imported the logo from AutoCAD as a block but cannot seem to be able to paste this block into the title block.
STEPS
In a DWG file right-click Drawing Resources\AutoCAD Blocks and select Import AutoCAD Block.
Select an AutoCAD drawing, select the block to be imported from that drawing and click INSERT
Click anywhere on the worksheet to place the block; right-click and select DONE.
The browser now shows the inserted block.
BTW: The block cannot be imported directly into the title block using the above method as the AutoCAD Blocks node in the browser is greyed out while editing the title block.
Now that the block is in the browser I can place as many as I like into the drawing by right-clicking the block in the browser, selecting INSERT, then clicking at various points in the worksheet.
Again, this method cannot be used to place the block into the title block when it is open for edit because the AutoCAD Blocks node is again greyed out.
What am I doing wrong? How do I place the block into the title block?
Why is this operation different from blocks in an IPT? Some consistency would be appreciated.
This topic is almost impossible to Google because "AutoCAD block" and "Title Block" pull up articles about each individually as well as articles about blocks in IPT sketches. A dedicated article would be appreciated.
gcoombridge
I don't think it's possible to insert blocks into the title block. 2 options:
  • Insert the block in the template file in the right position outside of the title block using the attachment points (if ACAD blocks have those - I never use them in Inventor). This would mean the user could move them.
  • Explode the block in ACAD and copy and paste it into the title block definition. To avoid having to constrain it use the sketch move tool to locate it.
Use iLogic Copy? Please consider voting for this long overdue idea (not mine):https://forums.autodesk.com/t5/inventor-ideas/string-replace-for-ilogic-design-copy/idi-p/3821399
Fouad-l
Hi @SEC_CAD.
You can insert an Autocad block into the title block the same way you do in a sketch envirenment.
- right click the title block -> edit definition.
- now you have a sketch envirenment -> insert -> ACAD
FOUAD LATRACH - MECHANICAL ENGINEER - ELCHE - SPAIN.
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
ASUS ROG G703 : Windows 10 Pro - Intel i7 3.4 Ghz - 64 Gb RAM - 1.5 TB SSD - Nvidia GTX 1080 8GB.
SEC_CAD
@Fouad-l This does not insert an AutoCAD block into the title block. At best it brings in the vector lines as separate entities. I could already do this. I want the logo to be inserted as a block.
@gcoombridge Thanks. I think that you must be right and that Inventor cannot do this.
