Hi, I have a model which created by iPart and this table is generated by " General Table". Is there any way that the tolerance can be shown on this general table like photo above( red color )?
could be done easily with a custom property....
share an example or what you have ...
but if it was me .. and it was a general table ..the H7 etc would alreay be there ...
so for say S120, The next file would already have H7, and populate the 120, the 127 and the plus/minus would be already there ...etc etc ..
Hi, How to do it in custom properties ?
The tolerance H7 is no populated in the general table.
A lot of different ways ..here is a quick google search.
You make them in the iproperties custom box
You could make on for Tolerance in the name tab and H7 or h7, F7 f7, JS9 etc in value ...
By creating a new iproperties, the tolerance will only populate at the different column in the general table.
For my case, I would like to have both number and tolerance in one column(see photo).
I'll look at it at some point today
I have forgotten you ...
Quick question is this a parts list or a General table added? I want to be 100% sure.
How is it populated with the 120, 130, 140 ...
this is general table ..
The value 120, 130, 140 is populated from the ipart table
