How to get rid of unresolved links
AIR_123
Message 1 of 10
AIR_123
I have and assembly made from multibody part.
Each part in the assembly is referencing parent part.
If I open each part of the assembly and break the link to the parent part I see this confirmation icon.
After I save and reopen the assembly, it is still looking for parent part in each component derived from it.
Why it happens if link is broken? how can I fully unlink the parts from the parent part?
__PRESENT
Replies (9)
Message 2 of 10
johnsonshiue
Hi! Go to the browser and find the search bar -> click on the unresolved button. The components with unresolved files will be listed.
Many thanks!
Software Test Engineer
Message 3 of 10
AIR_123
Hi Johnson, I dont understand your reply.
I dont look for unresolved links, I want to get rid of dependencies
Here is the result of your suggestion, if that is what you mean
Message 4 of 10
johnsonshiue
Hi! Yes, that is what I meant. But the issue you are seeing could be a corruption. The assembly assumes the link still exists but the link was already deleted or broken. Please share the files with me directly at johnson.shiue@autodesk.com. I would like to understand the behavior better. Or you may try demoting the components to a new subassembly. Then use the subassembly as the top-level assembly. This is the only way to purge the corrupted link.
Many thanks!
Message 5 of 10
AIR_123
Thanks Johnson,
Email sent, please post your findings here (not the model ;)). Thanks
Message 6 of 10
johnsonshiue
Hi! Many thanks for sharing the files! I took a quick look. I notice the unresolved components are all nested in the Bolts folder. It seems to be that the CC parts cannot be found. Is this what you are talking about?
Thanks again!
Message 7 of 10
AIR_123
@johnsonshiue
Thanks for looking Johnson.
No, that is not what I mean.
Because I've used PackNGo you have parent file on your side in the same folder, which is this one "....v3_orient.ipt".
For me this parent file is in different project folder and should not be linked anymore to current one.
If you remove this file on your side and restart the assembly, all children parts will be missing link to the parent "....v3_orient.ipt".
I went to all those child parts and broke the link to the parent. After I restart assembly it is still looking for the parent, ignoring broken link.
Message 8 of 10
johnsonshiue
Hi! Many thanks for the clarification! The only way to get rid of the link is to break it. Suppressing the link still keeps the link alive. You will need to open each derived part and right-click on the derive feature -> Break link.
Thanks again!
Message 9 of 10
AIR_123
yes, that is what I did, but after restart of the assembly, all those children are still looking for the parent... that's why the question, why this is happening?
Message 10 of 10
johnsonshiue
Hi! I am not seeing such behavior. After the links are broken, I am not prompted to resolve the files. Please share the files with broken links with me directly at johnson.shiue@autodesk.com. I would like to understand the behavior better.
Many thanks!
