how to extrude a circular Pattern on a curved side Surface
Message 1 of 31
Hi
I am looking if someone can tell me the instructions:
-I am working on a coin redesign concept
-I want to paste an extruded circular pattern of the dollar Sign Symbol around the curved side surface of a random coin.
-I have looked everywhere but can not find the right solutions
Could somebody help me how i can achieve this.
Greets, Peters
@JDMather
Accepted solutions (3)
Replies (30)
Message 2 of 31
SharkDesign
Do you not just extrude one and then circular pattern it?
  Inventor Certified Professional
Message 3 of 31
Yes that would be awesome if i could do that, but the problem is that i can not sketch anything on a round side surface of it. on the plan surface it would work fine
Message 4 of 31
SharkDesign
You need to make a new plane tangential to the curve.
Then create a new 3d sketch and use project to surface to put the sketch on the curve.
There are various ways to extrude it from here. Try emboss as a starter.
If you still need help, let me know and I'll do a video in the morning. Unless Mr Mather is doing the night shift 😀
Message 5 of 31
Allright i am gonna try it now and let you now Asap if this works for me.
Message 6 of 31
I am getting an error that says: Emboss Failed: the profiles extend outside the body?
is there a way to adjust the work plane equal to the surface so i will not extent it?
Message 7 of 31
Message 8 of 31
leowarren34
Hi @Anonymousl,
This is specifically to do with your sketch, in that it goes beyond the solid, see below:
The produces the same error 'Emboss Failed: the profiles extend outside the body?'
The way to correct this is to move the sketch profile within the solid, which for me would be the grey stripe.
Can you upload what you have done so far?
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Message 9 of 31
SharkDesign
Try it like this:
https://knowledge.autodesk.com/community/screencast/9ee9a6c5-14b5-4d18-a032-6081a3144236
Message 10 of 31
JDMather
Attach your file here.
The forum is currently broken - you have to Reply-Post-Edit Reply to get access to Attach.
Message 11 of 31
Yes this was exactly what i was looking for, Could you do me a favour and also screen cast the the way you have created the workplane
Message 12 of 31
JDMather
Turn on the Visibility of one of the Origin planes.
Select Plane and click and drag offset plane from the Origin plane.
Message 13 of 31
SharkDesign
Click and drag a plane, or click the plane and click the face, as shown here:
https://knowledge.autodesk.com/community/screencast/53922987-505f-467d-bdf5-9b8b5696644d
Another method of making planes not related to your project, but useful to know:
https://www.youtube.com/watch?v=lDXsnsL2n8E
Message 14 of 31
Yes it has worked out for me, but i have a related question on the topic. now I want to paste the extruded pattern on the side surface of the part i have attached in the attachment.
I am getting stuck at the following things:
-Which Patern type should i use?
-I was thinking to merge the faces so i would be easier to paste the pattern on it.
-I am getting stuck because the 3 different faces that i can not select with the pattern.
-the round surface have been created with a filet
Message 15 of 31
JDMather
@Anonymous wrote:
.... of the part i have attached in the attachment.
Attach the *.ipt file here.
You will have to Reply-Post-Edit Reply to gain access to the attachment box.
Message 16 of 31
The part is from a 2017 version of inventor  i am using temporarily
Message 17 of 31
so the core core question is more how i can paste a extruded pattern on the side because it have 3 independant faces. When I try to use a circular pattern it only let me select one face in stead of all 3
Message 18 of 31
JDMather
@Anonymous wrote:
so the core core question is more how i can paste a extruded pattern on the side because it have 3 independent faces. When I try to use a circular pattern it only let me select one face in stead of all 3
I do not see your *.ipt file Attached.
I do not see extruded pattern on the side of any of your 3 independent faces.
Circular Pattern would not make logical sense.  This would be a curve driven pattern or possibly some other technique depending on the geometry to pattern. (Emboss-Wrap, 3D Sketch Wrap)
Message 19 of 31
the pattern is just a normal dollar sign, can you help me out how you would do it
Message 20 of 31
SharkDesign
