How to engrave text and designs on a curved surface
rcobbjr
rcobbjr
The part (see JPEG attachment) has text and lines engraved on a curved surface (see PDF attachment). I have tried to create a workplane and I have tried converting the surface into a 3D sketch and 3D surface but was unsuccessful. How do I ENGRAVE the text and lines into curved surface (highlighted in the JPEG) of the part?
Cadmanto
Create an offset surface just below the outside surface.
Then create a plane just above the exterior surface to place your sketched text on.
Then project that text as an extruded cut to the embedded surface.
Make sense?
https://www.youtube.com/watch?v=K-XwGr_5j1A
https://www.youtube.com/watch?v=DPuF2crhqvw
See attached sample
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2018
Best Regards,
Scott McFadden
(Colossians 3:23-25)
johnsonshiue
Hi! Please follow Scott's approach. If it does not work for you, attach the file here so forum experts can take a look.
Many thanks!
Software Test Engineer
