Announcements
How to Enable the Adaptivity of a part/subassembly in Assembly
BeKirra
BeKirra
After the assembly being updated a couple of times, I notice the Adaptivity of one of the components is grey out when I right click it.
How to re-enable it?
Thanks.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
pcrawley
Open the component - go to Tools > Document Settings > Modeling - and uncheck "Adaptively used in assembly".
Peter
BeKirra
Great!
It is the answer.
Thanks @pcrawley
X² + Y² = C²
johnsonshiue
Hi! Another possibility is that the part itself contains a non-Primary Model State. Once it becomes table driven, the adaptivity will be disabled. The same behavior can be seen on converting an adaptive part to an iPart.
Many thanks!
Software Test Engineer
