Hi all I have a sheet in a inventor drawing package I am generating that has a bunch of parts detailed out on the one sheet. The problem is the first item I put on the drawing was at a certain scale. Due to some parts being very large and others just being a foot or two across I have parts on the sheet at many different scales with scale noted at the part. I want to change the title block scale to say VARIES. However in the edit properties field the initial view scale on sheet properties is greyed out. This is not able to be controlled by illogic as that is also greyed out. How does one go about changing sheet properties on one sheet in Inventor?
