How to edit iProperty that is not exposed in the user interface?
XYZ965
Message 1 of 10
XYZ965
For example, I want to use iProperty Manufacturer, but I don't see it in iProperties dialog box.
Property with that name exist in the List of Inventor pre-defined iProperty names.
Thanks.
Replies (9)
Message 2 of 10
CCarreiras
Hi!
Is this it?
CCarreiras
Message 3 of 10
XYZ965
Thank You very much for quick response, but I don't want to create new Custom iProperty if the property allready exist in predefined Inventor iProperties.
Message 4 of 10
CCarreiras
The "Manufacturer" field might be part of a specific template, and if you are not using that template, it won't be visible.
If the "Manufacturer" iProperty is still not visible, you can create or add it manually as a custom iProperty.
CCarreiras
Message 5 of 10
XYZ965
In fact, I would like to use iProperities like Sheet Metal Width, Sheet Metal Length ...
Thank You in advance
Message 6 of 10
XYZ965
May be I'm wrong, but list of Inventor pre-defined iPoperty names  I get via VBA code in my part file. And iProperty with name Manufacturer was listed.
Message 7 of 10
johnsonshiue
Hi! I guess you will need to use iLogic. Indeed it seems that "Manufacturer" is a predefined iProperty in "Project" category. Use the following statement to assign the value.
iProperties.Value("Project", "Manufacturer") =ADSK
Many thanks!
Software Test Engineer
Message 8 of 10
XYZ965
Thank You very much. Your answers always save us a lot of time.
Message 9 of 10
XYZ965
Message 10 of 10
johnsonshiue
Hi! Many thanks for your kind words! But I am also aware that my ill-informed suggestions wasted users' a lot of time.
Thanks again!
