How to edit a section view line
curt.darius
curt.darius
Is there a way to edit my section line A-A from 0 to 90 degrees to the right through the middle of the piece? I kinda edited my section view, and don't want to make another section. Thank you
admaiora
Right click the section line, Edit. (if you have Inv 2016 make sure to have installed the new Update)
If the section line doesn't move you have inferred the mid center hole. So you have to remove the constraint > F8, hover the yellow square, right click>> delete.
Or, you can do the section fronm the beginning.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
curt.darius
I can also do this with Inventor 2014?
admaiora
Sure.
Just edit the section line, unconstrain, constraint and dimension it again , that's it
Admaiora
curt.darius
So I did what you said, but now I only got 1 arrowhead. What's wrong?
admaiora
Inventor is right, You have to draw  a third segment
Admaiora
