How to draw this irregular form
I need to draw this form, but I can´t get the helix option.
Can You help me?
Step By Step or Suggestions. This format is helical and circular. Desenho Irregulas.png
johnsonshiue
Hi! It does not look irregular to me. You need to focus on 1/6 of the model (pattern 6 times later). The path looks like projected to a torus (donuts). It should be doable. Please share your attempt here. Forum experts can help provide further guidance.
Many thanks!
Software Test Engineer
JDMather
You can get the sweep path via a 3D intersection of torus surface and curve.
Attach the *.ipt file of your attempt if you can't figure it out.
lena.talkhina
Hello @Anonymous  !
Great to see you here on Inventor Forum.
It's been a month since we last heard from you in this thread. Did you model the thing?
Don't hesitate to accept as a solution the  post from @JDMather  or @johnsonshiue  if their ideas help you.
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
